Since the latest update, it is no longer possible to open a folder with routes, then click on one of the routes and open it in a new tab, which was very convenient. Instead, now the route opens in the same tab and when you want to go back by clicking on previous in your browser, you are taken back to your list of journeys, which is not very convenient.
I noticed that this has also changed when you do this on a smartphone.
Any chance of getting that feature back?
Regards
Philippe
I confess I’m not 100% sure what you mean here – if you go to your journeys page, you can still use whatever your browser’s keypress is (on my Mac it’s command+shift click) to open in a new tab. Is it something else you’re referring to?
You understood that right but it doesn’t work anymore, neither on my Mac nor on my iPhone. Maybe it has to do with the latest updates. That function still works on other sites but not on yours anymore, at least not with the right click as it used to. I will try it using the shortcut you mention.
So, here is what I noticed (I will try to be clear):
If if click on "map" next to open a folder with several routes and then try to open one of the routes in a new tab, it doesn't work, neither with a right click nor with the shortcut with command and shift.
If I right click on the name on the folder, I can open it in a new tab and then right click again on the routes and open them in a new tab.
Thanks – that’s helpful! I’ve just tweaked it and you should now be able to open in a new tab from the list on the main map page. Let me know if that works for you.
Yes it works fine now. Thank you.
